Tom's Hardware > Forum > Homebuilt Systems > New System Build > New system, please review (with links!)
Forum Homebuilt Systems : New System Build - New system, please review (with links!)
Here is the new system I would like to build:
MOBO AND CPU: Asus M2N-MX SE Plus Motherboard CPU Bundle - AMD Athlon X2 4400+ GHz Processor OEM
http://www.compusa.com/application [...] cket%20AM2
COST $99.00
COOLING: Ultra X-Wind Aluminum Socket K8/AM2 CPU Cooling Fan
http://www.compusa.com/application [...] CatId=2545
COST: $19.99
HARD DRIVE: Seagate Barracuda 7200.11 500GB Hard Drive - 7200RPM, 32MB, SATA-300, OEM
http://www.compusa.com/application [...] CatId=2459
COST: $69.99
MEMORY:
OCZ SLI-Ready Dual Channel 4096MB PC6400 DDR2 800MHz Memory (2x2048MB)
http://www.compusa.com/application [...] =O261-8038
COST: $39.99
DISK DRIVE: Sony DRU-V200S/BR DVD Rewritable Drive SATA
http://www.compusa.com/application [...] =S167-4520
VIDEO CARD: (I already have a X800 GTO)
So, my questions are this:
1. What am I forgetting?
2. Are all these parts compatible?
AMD Sempron 3100+
1280MBS PC3200 RAM
RADEON X800 GTO AGP 256 MB
Sponsored Links
Your X800GTO has an AGP socket, the motherboard has the PCIex16 socket so your old graphic card is not compatible.
Reply to dirtmountain
Exactly. Besides, keeping the old X800 would leave you with no DX10 (which is acceptable) and no shader 3.0 support (which is a major setback for gaming).
Reply to Murissokah
Ah, good point.
Other than that though, things look solid? I can always just upgrade my Video Card later.
As a photographer, I am sure the standard on board graphics card can handle the photos I need to do. But with my current machine, which has the X800 GTO for gaming, I dont really "game" much at all anymore... I just use it for work!
EDIT:
I guess I just need to make sure that the HD and RAM work with the MOBO. I am pretty sure the RAM does, but I am confused on HD's and what they are compatible with.
Can someone explain?
Message edited by RMThompson on 10-02-2008 at 06:30:47 PM
AMD Sempron 3100+
1280MBS PC3200 RAM
Reply to RMThompson
Can ANYONE confirm that the HD and RAM work with this MOBO???
AMD Sempron 3100+
1280MBS PC3200 RAM
Reply to RMThompson
You didn't list an operating system, are you using Vista or XP? Yes they are compatible
I think I am going to buckle down and purchase Vista. I mean, it can use all the RAM, and that will mean for a smoother system overall.
AMD Sempron 3100+
1280MBS PC3200 RAM
Reply to RMThompson
There are 838 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
