790i ultra motherboard help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - 790i ultra motherboard help
ok so i wanted to upgrade my xps 630 from the **** 650i motherboard to the 790i ultra motherboard and my questions are willl it fit fine in the case and would i encounter any problems?
Thanks
Sponsored Links
Knowing Dell the mainboard is probably proprietary and modified enough that you wont be able to.
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
i think that the motherboard you have now is terrible, knowing what dell probably shipped it with. so yea, you should upgrade your motherboard.... the matter if it fits or not, um i think it would fit fine, but you should definitely call dell or look into that.
Reply to mirob93
salabarria,
You're motherboard is of standard ATX configuration ( other than the 8x only PCIE slots ) and is replaceable with any other ATX board of the same size.
You really should hit up the Dell forums, they have sections there dedicated to the XPS630. Another forum option would be My630i.com
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > 790i ultra motherboard help
There are 1200 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
