First of all, I am pretty new to this. I know the basics and i have done some research. But i am still unsure of myself. i will be using this computer for gaming and school work. If u have any suggestions for different parts than above feel free to add. I am on a $1000 or less budget. Questions: 1. Do you see any inconsistencies in compatibility? 2. Do i need extra cooling for my graphics and CPU? -Other than stock heatsink and fans:::: and case fans?? -I probably wont be doing any overclocking until I research more about the process and possible consequences 3. Does this motherboard support enough to cover future upgrades?? (1-2 year upgrades) 4. Would Vista be the wisest choice when buying a new gaming comp?
Message edited by fire443 on 10-03-2008 at 01:39:05 AM
I'd get this RAM instead. 2x2 GB DDR2 800 1.8v $57 after rebate.
http://www.newegg.com/Product/Prod [...] 6820146731 Geta a SATA burner, not the IDE one, it's faster and you won't have those oem ribbon cables.
1. It would work as posted, but i listed changes i feel are worthwhile.
2. If you overclock you will, but stock you'd be fine.
3. Yes, it's a quality motherboard with an option to crossfire another 4850 in the future.
4. Vista Home Premium 64
Message edited by dirtmountain on 10-03-2008 at 06:19:25 AM
If you're going with the Asus branded 4850, I suggest you get an aftermarket heatsink, as the stock one they provide is very, well, weak(referencing this one;http://www.newegg.com/Product/Product.aspx?Item=N82E16814121253). I liked a few other OEM offerings when I just browsed newegg- Palit's particularly.
Next thing; your psu! You certainly don't need one that large! I read an early review on this from another website, can't recall off the top of my head...I go to too many x_x http://www.newegg.com/Product/Prod [...] 6817341017
Modular, Efficient, Quiet, and a decent price. Thoughts?
I'd go for a q6600 with a decent heatsink and clock it to ~3ghz. You -could- get the dual if you want, it'll add some frames over the quad for sure. The better side of my ego is getting to me though, and I see having the extra core as a benefit for everyday multitasking.
Message edited by effel on 10-03-2008 at 09:20:46 AM
I think the 750TX is a good PSU for a possible future 4850 CF.
The new 600W OCZ does look promising, but I've seen a few notes here and there that make me want to wait before recommending it.
The only review so far that I found was at Fudzilla. It is not the kind of review I would trust: "We hooked it up to a few systems and it worked, so it must be good."
Oh yeah, by all means, if the OP has intents of Crossfire'ing in the future, the Corsair is great. I see what you mean about not being an early adopter of such a product without more reviews though-certainly seems justified.
OCZ now owns PCP&C, and with their(OCZ) recent releases, it seems like they are taking hints from the quality/success associated with PCP&C though. Good for them.
