Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Problem with new PC Build
Forum Homebuilt Systems : General Homebuilt - Problem with new PC Build
First time building a PC so need a little help. Basically got all the hardware connected and working.
But the problem is when I try to install a copy of WIndows XP Pro it either hangs at certain points or when it finishes loading all the drivers it will just reboot the computer. I cant even get to the partition your Hdd screen.
I tried Vista but it also hangs and when I get through I get a screen like could not boot please insert your installation cd and restart.
Here are my specs
asus pq5 pro
9800gt
e8400
hitachi sata 2 hd
samsung dvd-rw
500 watt psu antec earthwatts
Sponsored Links
How much ram & how many sticks? Try upping ddr2 voltage a notch. Best do memtest for 8+ passes:
http://www.memtest.org/#downiso
Reply to auscanzukus
Hi thanks for replying I have 2x 2gb sticks.
Reply to westell220
Do what I suggested.
There are 1408 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
