G
Guest
Guest
Hi,
Just installed the motherboard and all that is required. Downloaded the latest chipset and audio drivers and connected the MB to my receiver via the onboard SPDIF-out. Issue seems to be that the sound is intermittant. Hence it does produce sound, however it keeps pauzing/muting every few seconds.
Changing settings in the Realtek or Microsoft software does not give any solutions. When changing though I can see that my receiver picks up the change when going from 2.1 to 5.1 or Dolby DTS. The receiver also worked with my previous board, so not assuming that is the issue.
Any solutions or suggestions?
Specs:
MB: Gigabyte GA-MA790GP-DS4H
CPU: AMD Athlon X2 5050E
Memory: 4x 1 GB 800 Mhz
OS: Windows Vista Home Premium 32bit
Audio chip set: High quality 106dB SNR ALC889A HD audio
Regards,
Emile
Specs:
Regards,
Emile
