T terry wendland Distinguished Mar 10, 2011 1 0 18,510 Mar 10, 2011 #1 Hello, unable to scan to file,except thru paint. seems to be a problem with twain scan,also i have no solution center
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Mar 10, 2011 #2 Unisntall the scanner from the system. Download latest drivers, install following the directions, check again. From your solution center blurb, it's an HP scanner, their software will give you a few options to scan to, but you need to install it. Upvote 0 Downvote
