Hello,
It's been several years since I've been on this forum. So long in fact that I cant remember my username. Anyways here is my problem. I've recently turned back on a computer that I left at my parents house several years ago that has seen minimal use in 2 years or so. My cpu (athlon 64 2800+) is running extremely hot (idling around 60-65 c). Before I turned the computer back on I made sure to clean out any dust that was inside the casing and made sure all fans were running properly.
Specs are:
athlon 64 2800+
msi k8n-fsr neo
ati 9800 pro
I can't figure out why it is running so hot. When the computer was in daily use idle temp used to be around 28-32 c. The motherboard is reading around 30 c so I don't believe it''s a airflow problem considering nothing has been changed inside. I tried turning off cool n quiet and it made no difference. Can anyone possibly tell me why this is happening? I did update to service pack 2 for xp pro but i don't think that could of caused this.
I checked in bios and the temp was about the same so it's not the program I'm using. I thought it could be a sensor problem but the heatsink is hot to the touch.
any suggestions?
Specs are:
athlon 64 2800+
msi k8n-fsr neo
ati 9800 pro
any suggestions?
