Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 4870x2 Loud Squeel (BAD CRYSTAL)?? Help!
Forum Graphic & Displays : Graphics Cards - 4870x2 Loud Squeel (BAD CRYSTAL)?? Help!
So I have a 4870x2 and it has a loud electronic squeel coming from it only when under load IE all games 3dmark ect. I have changed the PSU for another, taken out the GPU and played games on the onboard GPU, switched the PSU connectors, reinstalled the OS and used all kinds of drivers. Its not the fan either.
I talked to a Sapphire tech support guy (american) and he said it could be a bad crystal and to send it in for RMA. Ive never heard of a Crystal? on a gpu before.....Is this guy smokin something?
Thanks,
Specs:
OS:Vista Ult 64
MOBO: Asus m3a78-t 790gx
CPU: AMD Phenom 9950 BE
RAM: G.Skill 2gb
GPU: Sapphire 4870x2
HD: 250 GB WD
Case: Antec 900
Drives: CDR-DVD 52x
PSU: PC Power and Cooling 750W Silence
Sponsored Links
seems like a common issue with the 4870x2's. Apparently it's capacitor whine which causes it. From what I read it doesn't affect the card at all (except for the annoying noise )
Reply to deardeath
It is probably capacitor whine, if you want the noise to go away you have to RMA it. Not so much an issue confined to just 4870x2s, more like anything with capacitors.
Reply to skywalker9952
There are 473 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
