Like most, I would love to play Crysis/ Far Cry II with max settings (and perhaps some AA if possible). I don't mind compromising in the short term, and waiting and upgrading as tech progresses. This approach seems to be the sensible one.
Though I haven't done it yet, I am still working out a budget. I don't have an infinite amount of money to spend, but have been saving up and would like to build new OC'able system. I game a lot, but also use my computer to multi-task while working. If possible, I would like the system to have some future upgradability.
Oh and this will officially be my first water-cooled build.
I plan on building the computer within the next few months. Any advice on the best time to build/buy would be great too.
Here's what I have so far, thanks guys!
~Max
Note: I don't think there are any compatibility issues in the system below, but your vigilant eye is much appreciated.
Cooling Solution: Water Cooled (Since this is my first water cooled build, I am not sure if I am missing anything below. I was thinking that maybe it would be best to get like a full package instead of all the components separately. If you know of a solid water cooling kit, then I will go with that.)
Non Kit Version: Swiftech MCP655 Vortex XP Cpu water block Innovatek Dual Radiator Rad BOX XSPC Passive 150mm Reservoir Storage: 2 74 Gig Raptor Drives Raid 0 (I own one already, and found a second one online for a fair price.)
Any additional recommendations? I was thinking about replacing the fans with cooler more efficient ones, but am not sure what I would need if anything. I would like to keep the system as cool as possible, but still quite.
Thanks!
Message edited by Diaa on 10-06-2008 at 12:25:31 AM
Actually, I was just looking at the parts list. You say you won't be buying this in the next month, so further discussion is pointless on the motherboard, processor, or RAM. Your options will have changed drastically by then.
It's a good case.
The Corsair 1000HX is an excellent PSU, but you would likely need something even larger for 2 4870X2s. Perhaps a Silverstone 1200.
What do you think of the COOLMAX CUQ-1200B for a 1200W psu? It seems to have really good reviews online. I've gone ahead an updated the build with a 1200w psu as per your recommendation.
Also, you think that things will change that quickly on the mobo, processor, and ram if I build next month? Wow, well I may go with the same specs to save some money...unless there is a really compelling reason to hold off.
I've been out of the loop for a while, so I am not really aware of the latest trends.
because you are gettting a quad not a dual core so i think there isnt any future upgradable path for the system in a whole apart from DVD drive,HDD and graphics card you can upgrade!LOL
because this is the last decade of the socket 775.
iluvgillgi ll: I think I follow what you mean, but could you elaborate a little?
Any advice on what the best approach to take with be? When do you think socket 775 will be obsolete? & Finally, is there a different mobo that you recommend?
I hate to admit it, but this is news to me.
Thanks!
Message edited by Diaa on 10-05-2008 at 05:06:40 PM
its not say this thing will be useless in 6 months but i just wanna tell you that the next gen CPU is just around the corner which use socket LGA1366. so apart from the graphics card and HDD and DVD drive and possible PSU can be use in the new socket if you do want to do a full upgrade. other parts such as mobo,CPU(obviously) and memory will be incompatible with the new socket
by no mean the Q9550 you got now is slow compare to Nehalem.it will be still very fast specially when you OC.
the build you got now is pefectly fine!good choice on parts!
Thanks iluvgillgi ll! Hm, that's something to think about. I'll probably be rebuilding the system in about 3-4 years (that seems to be the general cycle), and so I wonder if it's better to wait a bit.
I've done a little research and read that Nehalem may be released in the coming months. This site even predicts an october release ( http://www.houstonbeats.com/board/ [...] p?t=106830 ). ...I'd hate to have 8 gigs of ram , a cpu, and a mobo that won't work with the next generation (especially if it is a substantial improvement).
Any idea if compatible motherboards/ram sticks are available, or is it dependent on the cpu's release? I'm guessing the motherboards won't be backwards compatible.
hm, ok I think I may be waiting for a little while unless I'm missing something. Maybe 2-3 months?
Thanks a lot iluvgillgi ll , you've been a huge help. I wouldn't have thought to even consider Nehalem until you brought it up.
Message edited by Diaa on 10-05-2008 at 05:31:59 PM
It seems to suggest that the DDR3 ram I chose would work with the new mobos? If so, then I'll probably upgrade now. It's easier to switch out a mobo and processor when I can keep the (relatively expensive) DDR3 Ram.
Also something that caught my eye was that (according to the thread), gaming improvement may not really be seeing a huge jump...at least not for a while.
The new CPU class, renamed i7, will run on the x58 chipset initially, although others will follow.
Since you are looking to crossfire and prefer to use the system for a number of years, it only makes sense to wait for x58.
I can't say much for the Coolmax PSU. I see no good tests on that model. Some models of lower wattage from them have bad reviews, while the higher wattage PSU they offer has good reviews.
Thanks Proximon, im looking into the Tuniq now as a possible alternative.
I think I may wait for the i7 to come out just so prices drop a bit. Everything I've read suggest that the new chips won't be geared towards gaming, and will most probably be out of my league at release.
or you can always get the 45nm chip as they will be substantially cheaper when i7 is out and offer similar performance at a much lower price hence better value for money.
