System for gaming, Photo, mostly have a few large databases. Probably run it as stock, OCing might be done. Currently playing LOTRO, Conan, and warhammer online so the heavy use will be gaming,
at about 1900 so far but,,,, need a monitor and really lost here. I want 24 inch but need to stay around 400 to max 500 hundred
I realize the smart thing maybe to wait a year for new CPU's, then it turns into 2 years for availability and prices to come down.
I am off cycle on my purchases, even my HD TV was the last year that rear projections where big. The next year was flat screens and HDMi.
so i will have to live with that as I need a new system now,
Thanks for your help In advance
Message edited by Tym on 10-05-2008 at 04:31:13 PM
I'd probably go with this:
q9400 - Save $50 and still will be able to OC to 3.2 ghz and above with 800mHz DDR2 RAM. If you want to go much higher than consider 1066mHz, but 800mHz will do for 99% of OC's!!
2x 4850's - Save $200 over the 4870x2 if you think that this will be fine. Since your going to be at a 24" LCD, your resolution will work out just fine for 2x4850's!!! It's up to you here.
CM 690 Case - I'd consider this case over your selection, if you don't want to spend $185 for the one you selected. The CM 690 case is going for $78 shipped!! It has plenty of room and doesn't skimp out at all for the $!!!
Cooler Master 690 without Power Supply - RC-690-KKN1-GP
CPU HSF - Couldn't have picked a better selection for the price with the Xigmatek S1283!!
HD's - Look good there! You can get bigger drives, but that will depend on what you want to do.
Thanks for catching the memory issue. I did miss that. Going to get
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model 996599 - Retail
http://www.newegg.com/Product/Prod [...] 6820146785
Also looking at
BenQ V2400W Black-Silver 24" 2ms(GTG) HDMI Widescreen LCD Monitor 250 cd/m2 DC 4000:1(1000:1) - Retail
http://www.newegg.com/Product/Prod [...] 6824014177 Saw a few comments that i liked. I still looking at the samsungs also. I hear they changed the revisions alot on these monitors, And the specs change when they have someone else produce the monitor for them.
Going to purchase probably in the next couple of days. Still feel a little lost on the monitor I guess because the all spec out so close to each other.
