Tom's Hardware > Forum > Homebuilt Systems > New System Build > Ordering today!!! Any advice? Please help.
Forum Homebuilt Systems : New System Build - Ordering today!!! Any advice? Please help.
Ordering today!!!! Please help. Do you see any issues? Ordering off newegg.
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
Microsoft Windows Vista Ultimate SP1 64-bit English 1pk DSP OEI DVD for System Builders - OEM
LG 20X DVD±R DVD Burner w/ SecurDisc Tech Black SATA Model GH20NS15 - OEM
Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model KHX8500AD2K2/4GR
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
CORSAIR CMPSU-520HX 520W ATX12V v2.2 and EPS12V 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
GIGABYTE GV-R485ZL-512H Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
XCLIO A380BK Fully Black High Gloss Finish SECC 1.0mm thickness ATX Full Tower Computer Case
Sponsored Links
yeah everything is fine but the Vista Ultimate.dont recommended as it give you tones of useless feature and background service to eat up your resources.get home premium instead.
Reply to iluvgillgill
OK will do thank you.
Reply to auros
can you post a link to your case?
right i have got a problem. that case i have used for a build before.its a massive case and good build quality.BUT the side fan will disrupt the flow of air inside the case. so get a case with no BIG side fan.i recommend the Antec 900 or even 1200. or you can keep this case and turn up the side fan to cool the system in a brute force way.
your choice:)
I am confused, sry. What do you mean "brute force way".
Reply to auros
cooling the inside of the case use BRUTE FORCE kinda way just blowings tones of air on the component without thinking of the actual the direction of airflow inside the case.
understand it now?
Ah I see. That makes sense. Thanks for your help. I will switch to the antec nine hundred. You have been very helpful thank you so much.
Reply to auros
I personally would stick with Vista Ultimate. I use it and it is lightning fast and has lots of cool features.
Animated Wallparers, Drive encryption, and you can back up you entire system so if it fails you have a back-up image.
Reply to roadrunner197069
Will i have any memory issues with ultimate? My hard drive is this.
http://www.newegg.com/Product/Prod [...] 6822136218
Reply to auros
That's a very good hard drive. I don't expect any memory issues with that setup.
Are you going to play games a lot? If yes, spend an extra $20 and replace the 520HX with a 750TX. You'd have lots more room for upgrades, including the ability to add a second video card when/if needed.
Reply to aevm
There are 1356 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
