Should not be a problem for that Dell power supply - it's not a very powerful video card.
For comparison with some other budget video cards look at this review: ATI 4350 vs Nv 9400GT
I suppose its too late to change the order on the Dell 530s?
Good news. I voided the order and am getting refunded in full.
The next question.. With the specs I gave, and the power supply the inspiron 530s comes with, which i believe is like 220-250 watts... what is the fastest/best for your money vide card I can get?
Dell 530s has a 250w power supply. A 9600GT might run - but I wouldn't be surprised if it didnt.
The power envelope for a 9600GT runs to 60watts.
Any of the 3 you listed should run on that 250W PSU.
The 4550 should be a touch more powerful but will probably disappoint you if you're buying it for gaming.
Have your Dell upgraded to a 375 PSU.
Dell PSU's are under rated, the 375watt PSU supplies 18 and 17 amps on the 12 volt rails and pushes 30amps combined. Decent enough to run most any higher-mid range gaming card.
Then, get yourself a good graphic card. The ones you are looking at are quite underpowered. A 4830 would fit the bill nicely.
Needs the power adapter but would probably be fine.
I've got a 6 year old Dell ( P4-2.4 and RDRam ) with a 250 watt Dell psu and a Radeon 9800 (AGP with a floppy power connection [47 watts]), still running strong.
------------------------------q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
At 150mm W x 140mm D x 96mm H that won't fit the minitower , much less the SFF box.
Reply to Delluser1
I don't really think I wanna dish out the extra money for a power supply and a top of the line video card.
Any other video cards out there that fit the 75 dollar or cheaper range and can run something like Neverwinter nights 2 at medium-high graphics? Or which of the three I listed would be best for gaming and compatible with 250 Watts
I have this computer and bought a new video card for christmas and I can tell you from first-hand experience, the power supply in the 530s does not power the video card. It was this card: http://www.newegg.com/Product/Prod [...] 6814102800
The video card is fine. I tested it in my main machine and it works great, but the little power supply in the Dell isn't enough for it.
I just found this thread while searching for what kind of power supply the dell slim case uses, anyone know?
Too many people who don't know the difference between a compatibility issue and a power problem.
Your 2400 Pro uses less than half the amount of power that the 3450 Dell is currently offering in the 530s.
How can you tell how much power the card uses? Can you tell by the specs, if so, what specs? What is the 3450 Dell?
My main rig is an older Dell Precision 380, so I just find it hard to believe there is a compatibility issue. The card works in a motherboard of the same brand from over 2 years ago, why would it not work in the newer model? They both have PCI Express x16.
BTW jrogcsu, WR2's recommendation of the XFX Low Profile Bracket kit is very good, that's the same one I bought. It comes with 3 different brackets that pretty much cover all of your bases.
