my main concern is will that cpu bottleneck the video card. I dont think it will but what do u guys think? i cant go quad core cause i dont wanna buy a new mobo, i dont have enough money for that.
i will also have 4 gigs of ram by then. and a corsair 750watt psu.
after christmas huh? prices should go down by than.... i wouldnt be surprised if hd5000 series was fully announced by thn.. should drop prices nicely =]
FPS games at 16x10. I wouldn't bother with the 4870, get the 4850 instead. The CPU you picked out is good, but with the money saved you should be able to get a quad. You should be able to get the 9950 for the same price, and at 16x10, you won't notice the difference.
------------------------------The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
I would make sure your motherboard can use the CPU, and if the video card is still under warranty get it fixed and keep it as a spare or sell it.
Good choice on the video card, VisionTek is the only ATI card I would buy.
