Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Refresh Rate Problem =( plz read
Forum Graphic & Displays : Graphics Cards - Refresh Rate Problem =( plz read
Hi, I have a Sony BRAVIA 46 inch 1080P rear projection TV, I hooked up a computer with a diamond HD 3850 video card and was immediately able to set the resolution to 1080p @ 60hz, which the TV is supposed to support. When I try to hook up a computer with a sapphire HD 3870 and set it to 1080P @ 60hz (I have to force this refresh rate on this card) the image becomes too large for the TV. I have tried multiple drivers.. and no luck. The best setting I have gotten with the 3870 is 1080P @ 50hz or Optimized 1080p @ 60hz (not true 1080p, its 1776x10xx), but some games do not support that resolution so I am forced to use 24hz.. which tears. I simply don't understand why an HD 3850 would be able to produce 1080p @ 60hz and an HD 3870 is making the image to large. They have the same display engines. help please!
Sponsored Links
There are 678 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
