Going for watercooling soon, Purchase date roughly 3-4 weeks from now. I've done some research, (cheers conundrum for your informative threads )
My budget is £150 and I plan on building my own loop, rather than buying a pre-build loop
The loop will be cooling a Ci7 920 D0 only.
Here are the list of parts that i have choosen based on price/performance.
Rad. Swiftech MCR320-QP-K Triple 120mm Radiator
Pump + Res. XSPC Dual 750 Bay Reservoir Pump Rev2 Multi Fascia
CPU Block. Watercool HeatKiller CPU LGA1366 Rev. 3.0 LC
Tubing. XSPC 1/2" ID - 3/4" OD White Hose
Coolant. Distilled Water ( can I just get any kind of Distilled water? ) + PT PHN Nuke Concentrated Biocide 10ml
Fans. 3 x Enermax Magma 120mm
Adapter for CPU Block. 2 x 45 degree rotary adaptor G1/4" Black nickel + 1/4" BSPP (G1/4") HiFlow 1/2" Barb
Hose Clips. 10-16mm Hoseclips Pack of 10
Now I'm confussed about the barbs and the tubing, If the barb OD is 1/2" do I need tubing that has an ID of 1/2" or larger then 1/2"??
If something is crap in my Future loop, please explain why and perhaps an affordable (within my budget) replacement.
Thanks for any advice or recommendations.
