A ajaxojnr Distinguished Mar 12, 2011 1 0 18,510 Mar 12, 2011 #1 Hello,how to change the cmos battery of toshiba satellite pro m70
Solution peterdigby Mar 13, 2011 Hi, Try the following link - http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M70/remove-laptop-motherboard-1.htm Hope this helps, PD
peterdigby Distinguished Dec 3, 2010 46 0 18,540 Mar 13, 2011 Solution #2 Hi, Try the following link - http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M70/remove-laptop-motherboard-1.htm Hope this helps, PD Upvote 0 Downvote Solution
buwish Splendid Dec 16, 2008 9,854 1 31,460 Apr 16, 2011 #3 Best answer selected by buwish. Upvote 0 Downvote
