G
Guest
Guest
Hi there
I just tried to install a new Powercolor HD4850 PCS+ 1Gb on my PC. After boot, as soon as my PC detects the new VGA card it gives me a blue screen and reboots - yes I do login to it, only happens when my system detects the new VGA controller.
What I did:
- Removed old Gfx driver
- PC down
- Remove old Gfx card; Insert new one
- Boot PC
---- I dont get to install NEW drivers
I thought it was my PSU, so I changed it to a new one - problem is the same.
My system doesnt have that much connected:
- 2xHDD (1@40Gb; 1@120Gb)
- 1xDVD rec
- no floppy
- no extra sound card
- 4Gb DDR2 533Mhz
- CPU 3Ghz (Intel 775)
- MB Gigabyte 8i915P DUO rev 1.2 (original BIOS) (http://www.gigabyte.com.tw/Products/...ProductID=1801)
NEW PSU@550w with proper PCIE feed/6-pin connector
I run a winXP sp3 (full patch) - no "wierd" things in it, pretty much mainstream...
If anyone has any advise on how to proceed I'd much apreciated.
If you need any more info just ask - i'll be around
What I did:
- PC down
- Boot PC
- 1xDVD rec
- no floppy
- 4Gb DDR2 533Mhz
