Hi all I need some help to sort out a small problem that I have.
I had a Linksys WAG325N with a Sipura VoIP box connected. All worked fine until Sipura died and I had to replace it. Went to my ISP and they supplied a Billion 7401VGP-R3 and all works fine except now I have lost network access for one of my machines as the new 7401VGP-R3 doesn’t have the same wireless range as the old Linksys.
The million dollar question is can I connect the modem routers and use the WAG325N as my wireless router and just use the new 7401VGP-R3 as the modem and VoIP connection. If I can how do I need to configure them to get it to work.
Thanks
Sponsored Links
This is not the answer to your million dollar question but one workaround.
On the machine that lost connection, you can upgrade to more powerful wireless network card or use range extender.
Reply to JustAGuy51
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Home network setup problem
There are 1256 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
