Tom's Hardware > Forum > Homebuilt Systems > New System Build > plz help, first build!
Forum Homebuilt Systems : New System Build - plz help, first build!
for $600-$700, what is the best possible setup that i could get? because i want to kknow what i should be looking for.
(i'lll be playing games on a 20" 1680x1050 res monitor and would like to be able to play at 60+ fps on at least medium settings on most games)
Message edited by 0mg_1ts_m3 on 10-08-2008 at 07:54:30 PM
Sponsored Links
That is about the same budget I had building my system. Here is a link to my post. With the comments posted I was able to build a very nice gaming pc withing my budget.
http://www.tomshardware.com/forum/ [...] ing-system
Hope that helps! Good luck!
Reply to nachodonkey
This build would be superior in pretty much every way to the previous post:
SAMSUNG Black 22X DVD+R 22X DVD-R 16X DVD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/Product/Prod [...] 6827151173 $26.99
Intel Core 2 Duo E7200 Wolfdale 2.53GHz 3MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115052 $119.99
GIGABYTE GA-EP45-DS3L LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813128345 $104.99 -$15.00 MIR
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814102770 $159.99 -$20.00 MIR
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6820146731 $76.99 -$20.00 MIR
Corsair VX450W ATX12V & EPS12V Power Supply - CMPSU-450VX
http://www.buy.com/prod/corsair-vx [...] 66485.html $70.74 -$15.00 MIR
Antec Three Hundred Black ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811129042 $69.95
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822136218 $74.99
This comes to a total of $704.63 - $100 MIR = $604.63
You didn't mention whether the OS was to be included in the budget. You can pick up 64-bit Vista to take advantage of the 4GB of RAM for $100.
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
http://www.newegg.com/Product/Prod [...] 6832116488 $99.99
Edit: You could probably knock off a little more if you shop around for the case. Newegg's prices on cases and PSU's are not the greatest.
Message quoted 1 times
Message edited by shortstuff_mt on 10-08-2008 at 09:49:18 PM
Reply to shortstuff_mt
Wow, that's an amazing build for $600. Very nice work :)
Possible improvements: $17 more buys you a 650TX PSU, and $20 more buys a P5Q Pro. With these changes, you're all set to do Crossfire later and that will make your system last a lot longer. The P5Q Pro is not ideal for two HD 4850 cards, but it's only about 10% or so weaker than some ($100 more expensive) x48 motherboards.
http://www.buy.com/prod/corsair-tx [...] 78324.html
http://www.newegg.com/Product/Prod [...] 6813131299
Message edited by aevm on 10-08-2008 at 10:08:22 PM
Reply to aevm
Nice suggestions aevm. If you wanted crossfire capability you could also go with the GA-EP45-DS3R and save $13 over the P5Q Pro.
GIGABYTE GA-EP45-DS3R LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813128344 $126.99 -$20.00 MIR
I was trying really hard to get it in at budget, but these upgrades would be well worth it if you can squeeze them in.
Yeah, I should have said, there's no way to get all that and Windows and still keep it under $700. Still, for $750 or so you get incredible value these days. My own PC cost $3000 last year and it's about the same speed as this build of yours (it's got an 8800GTX in there).
Reply to aevm
+1. Also is the OP willing to learn how to OC?
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
$743.88 ($708.88 with mail-in-rebate)
ASUS 20X DVD±R DVD Burner Black SATA Model DRW-2014S1T - OEM
Item #: N82E16827135168
Return Policy: Standard Return Policy
Protect Your Investment (expand for optionshide options)
Service Net Replacement Extended Warranty Plan
The product will be replaced and shipped directly to you at no charge(more info)
1 year: $9.99
2 year: $14.99
$25.99
TRICOD 9003 Black / Silver SECC Steel ATX Mid Tower Computer Case 500W Power Supply - Retail
Item #: N82E16811240001
Return Policy: Standard Return Policy -$15.00 Instant
$74.99
$59.99
Seagate Barracuda ES.2 ST3250310NS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822148309
Return Policy: Limited 30-Day Return Policy
1 year: $14.99
2 year: $19.99
$79.99
Item #: N82E16814102770
1 year: $24.99
2 year: $39.99
-$10.00 Instant
$20.00 Mail-in Rebate $169.99
$159.99
Arctic Silver Ceramique Thermal Compound - OEM
Item #: N82E16835100009
Return Policy: Consumable Items Return Policy $4.99
mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996603 - Retail
Item #: N82E16820146764
1 year: $9.99
2 year: $14.99
$15.00 Mail-in Rebate $47.99
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard - Retail
Item #: N82E16813128359
1 year: $24.99
2 year: $39.99
$119.99
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
Item #: N82E16819115037
Return Policy: Processors (CPUs) Return Policy
1 year: $24.99
2 year: $39.99
$169.99
Thermaltake CL-P0370 92mm Enter CPU Cooler - Retail
Item #: N82E16835106085
Reply to jonpaul37
There are 1115 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
