My Pc work perfectly fine till 2 nights ago when i try to change the memory card to different set, but i miss up first 2 time forcing the motherboard which i put the long side on the wrong side and the tower make a big "CAAAAKKKAACAAAKK" sound dont know which one it come from. After that when i turn on the monitor dont work says "no input signal" had try with differnt ram (got 4 total) and reset the video card but none work.
So do u think it caused by video card?? if so im going to buy a new one but give me suggestion if tthis one is decent for a gamer
It sounds like you may have killed your motherboard. Are the fans in the computer still running? Do you get any beeps?
Try the RAM and video card in a different computer if you can.
What is your current video card? What resolution/size is your monitor?
the video card is 8500GT 2560 x 1600 all my fans are running including the video card and it doesnt have any beep and my monitor dont response with or without the ram not even a single message from the pc, and too bad i dont have any other deskptop computer i can test on.
What do you think might be?? video card or motherboard?
