Having problems, please help!
I built a new computer back in May 2008, and I'm having problems with a new headset I bought.
My old headset was a USB headset and it worked fine but I bought a new headset today that's not USB, it uses the green headphone and pink microphone jacks. Whenever I plug it in, my computer does not recognize it. I have tried the back and front jacks, I have restarted my computer several times and it's still not working.
Please help me, if you need my computer specs I can list them here.
Thanks in advance for the help.
6 answers Last reply
More about having problems help
  1. I'm assuming there's something wrong with my onboard audio, my motherboard is a Gigabyte EP25-DS3R.
    Please help, I just paid $250 for this headset and right now it's useless because my computer won't recognize it :(
  2. I'm also using Vista Home Premium 64-bit if that helps any.
    Please help me, I'm desperate!
  3. Your new headset will not require any drivers since it isn't USB, so I'm not sure what you mean by your computer "not recognizing" it. Are you referring to the jack sensing on your soundcard?
    Go ahead and tell us what headset you're using so we can have a better idea of what you're talking about.
  4. I'm using the Astro Gaming A40 headset.
    http://astrogaming.com/products/detail/4/A40_Headset/
    And by "not recognizing" I mean I have no sound and it says there are no audio devices installed.
    I've also installed the audio drivers from Realtek and from Gigabyte and they don't fix it.
  5. Is there anything else you need to know? I would like to fix this ASAP.
    Could there be a plug misplaced in my computer or something?
  6. I could really use some help, I'll take any suggestions and ideas.
    I already tried turning the Azalia Codec in my BIOS on auto but it still didn't work.
Homebuilt Gaming Headsets Computer USB Systems
