hey guys
Just built system
q6600
4870x2
4g ram
corsair 750tx
asus p5q pro
xp pro x32
when I go under the ati catalyst overdrive section and click on the card info button it gives me this info:
Primary Adapter
Graphics Card Manufacturer Built by ATI
Graphics Chipset ATI Radeon HD 4870 X2
Device ID 9441
Vendor 1002
Subsystem ID 2542
Subsystem Vendor ID 1002
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 011.007.000.000
BIOS Part Number 113-B50902-100
BIOS Date 2008/07/14
Memory Size 1024 MB
Memory Type GDDR5
Core Clock in MHz 750 MHz
Memory Clock in MHz 900 MHz
Total Memory Bandwidth in GByte/s 107 GByte/s
Disabled Adapter
Device ID 9441
Vendor 1002
Subsystem ID 2042
BIOS Part Number 113-B50902-101
Memory Size 1024 MB
Memory Type GDDR5
Is there a problem with the second GPU on this card? Im worried that it says disabled. Could this just be bc its in 2d mode, like a low power mode or bc of it being 32 bit xp?
Just want to know if I should be rma'ing this card.
No,he is talking about its card and u answered about RAM
To OP,download GPU-Z and run 2 copy of it and click on sensors tab on top and go to a game and play a game for about 5-10 mins with GPU-Z opened in background,then when u are in game press ALT+TAB to come to window and see if the clocks are the same or not.
HD 4870X2 has a power saving option which downcloks the GPU in 2d mode.
------------------------------Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
I did that, I think i was playing mercenaries2, the one core was loaded and the other was not. In the end I reformated with vista x64 sp1. Now when i go into ati overdrive it says both cores are linked prob solved
Thanks for the reply
This is fine the 1024MB is for one GPU, see? Theres the primary and second GPU, 1024MB for each, whats strange is showing Disable adapter, mine shows linked adapter
No problem mate well i had this problem before too,and with reformating like you it said both are linked
