The bios shows 86 when coretemp says 100 then I restart and look at bios. Its still a little hot. Last build I used this proc in was around 74 under load.
Trying the intel temp monitor now. Will post results.
If you havnt already, install the heatsink when the motherboard is outside of the case, you need to make sure the push-pins are in all the way and clipped.
Apparently the lame pins were not seating properly. Just removed motherboard and made sure heat sink was tight (one corner was not seated all the way).
Idle 43 and load 50.
I knew this was proper but just one of the things I forgot.
Thanks guys!
See, simple fix. Glad you got it working, saves alot of time, stress and money. This is a prime example as to why I always susgest installing ALL heatsinks, be it push pins or bolt throughs, before putting the motherboard in the case.
The stock cooler is not the best obviously, but its more than adequate for standard use.
Message edited by spathotan on 01-04-2009 at 05:13:41 AM
^meh, i had no trouble taking off the stock sink and installing a xigmatke hdt s963 with pushpins on mine... didnt even follow the instructions and worked first time
