First time building a computer. I've done a lot of research through various sites and had someone with experience building computers helping me pick parts. I was on a budget of about 1000$ and my final total came out to 980$ which will give me a little bit extra to spend on a monitor. I was able to buy some tax free / free shipping parts from Amazon which really helped me squeeze into my budget. Here's what I came out, any feedback would be greatly appreciated.
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146731
Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
x2 DIAMOND 4850PE3512 Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103060
The one thing I would of liked to do was possibly get a better mobo but the newegg combo was to good to pass up. I decided to go ATI route as I was getting a crossfire mobo in the combo and I was able to get tax free 4850's for 150$ a piece. I've heard mixed reviews on ATI vs Nvidia and crossfiring/sli vs not doing it, so I'm hoping I made a good choice here.
From what I've heard the 4850's run very hot which is a huge concern to me as my computer right now has overheating problems, so I'm very aware. Any suggestions for this, will I need to buy some more fans, etc? Or any other problems you might forsee for this setup?
Thanks very much.
Thanks very much.
