Wanted to do a screen capture to SHOW you, but can't paste it here.
On the tree, the MAIN FOLDER IS "RECIPES MASTER COPY", then, inside that folder I have numerous other folders such as, APPETIZERS, CHICKEN, DESSERTS, VEGETABLES, etc.
When I open one of those SPECIFIC FOLDERS, the various files (506 files in CHICKEN) are MOSTLY SORTED AS THEY SHOULD BE but there are about three at the top of the list that won't sort properly. I understand what you mean about numbers and/or characters, etc., and the numbers are where they should be. BUT, before the numbers begin there are THREE files that will NOT organize as they should. Here is what the files look like and the order they are in:
Fantastic Honey Chicken
Quick & Crunchy Chicken Crescents
Roasted Chicken with Tomatoes and Olives
15 Minute Italian Chicken and Rice
15-Minute Marinated Chicken
Adobe Roast Chicken
Aimee's Quick Chicken
Almond Fried Chicken, and so on down the line in PERFECT ALPHABETICAL ORDER.....it is those top THREE that will not
merge with the others in their proper order.
When I do as you said and right click anywhere in the folder background I do NOT have the OPTION to select ARRANGE. When I click on VIEW, then I have LIST selected with the little radio button. Then I go down the list and select SORT BY and NAME and ASCENDING are both selected with radio buttons.
If you've had enough I understand.....it has driven me crazy for months. Just send up the white surrender flag and I'll understand. Thanks again, so very much.
