Well, its that time again to build a new pc. I ran the numbers and now I'm excited. Here's my current build. Yes I'm going with AMD and I realize amd sucks right now and yes I'm low on money, don't try and persuade me to switch to intel. If I had the money I would.
Case: Thermaltake Matrix VX w/ 2 120mm case fans, 1 in front and back
Power Supply: Antec True Power II 430W
Motherboard: Asus A8V32-SLI Deluxe
CPU: AMD S939 90nm 4800+ 2.4ghz - overclocked to 2.6ghz w/ stock cooler (yes bad)
Ram: Corsair Twinx2048-3200C2 - overclocked w/ cpu of course (2GB)
Video Card: XFX 8800GT XXX Edition PCI-E 2.0
Hard Drives: (2) Hitachi Raid-0 sata-2 80gb
(1) Maxtor ATA133 160GB for backup purposes only
Optical: DVD+-RW LG ATA
OS: Vista Ultimate
The original reason for getting a new computer was that my video card was PCI-e 2.0 compliant but my motherboard was not so that's like a waste of money.
Here's the computer I will be purchasing on newegg.
Power Supply: Antec NeoPower 500w - $70 + 20% off until 10/12 making it $54
Motherboard: Asus m3a32-mvp deluxe Open Box - $133
CPU: AMD Phenom 9950 Black Edition - $174
Fan: Zalman 9700- $70
Ram: Corsair TWIN2X2048-8500C5D 2GB - $25 After $40 Mail In Rebate until the 15th
So that comes up to $457, pretty reasonably priced in my mind
But the kicker is that if I sell my ps, mobo, cpu, and ram on ebay, I came up with $400, believe it or not. That's what everybody has been getting for my exact same components.
My question for you guys is the power supply. In the asus manual for the motherboard, it recommends a 600w power supply. For what processor it doesn't say. I'm getting the best processor you can put in it. My Video card alone recommends 500w in non-sli form. I do plan to overclock the phenom as far as I can safely with fan cooling so I was also looking at the antec neopower 650w which was $95 after the 20% off, quite a bit more, which I would rather not spend obviously. I do not have any extra money. Do you guys have any other suggestions maybe on any other brands of power supplies? This motherboard has to have the 8 pin 12v connector which most do not have until you get above 500w. Thanks for all your help.
O yea, and I have to make a decision by tomorrow, the 12th by midnight because the 20% off the power supplies ends then.
OS: Vista Ultimate
