Tom's Hardware > Forum > Motherboards & Memory > MSI-Microstar > MSI X58 Eclipse "D-LED2"
Forum Motherboards & Memory : MSI-Microstar - MSI X58 Eclipse "D-LED2"
I have the MSI X58 Eclipse , it has the D-LED2 Onboard Lcd screen but it shuts down after a few minutes. Is there anyway that i can keep the D-LED2 perma on ?Maybe a program to control it ?
Thanx :-)
Sponsored Links
LOL @ MSI - expected
Sounds like PSU or Incorrectly Assembled/Installed HSF (thermal event)
List all the specs of your system (eg PSU = AcBell 300w TruePower Series etc)
------------------------------ Q6600@3510/1560 + TT BigTyphoon+Mod
8gb Kingston 800mhz
Gigabyte EP35-DS3P
XFX 8800GT/512
Reply to apache_lives
or maybe a 'screen saver' setting? power saving setting?
Reply to doormatderek
motherboard : MSI X58 Eclipse
CPU : Intel i7 @ 2.66Ghz
Ram : Apacer 2gb 1333mhz X 3 = 6gb
HDD : 500gb Seagate
GPU : MSI gtx260
PSU : In Win 850w
I hope this information helps , beacuse it works correctly everything i just also thinks it goes into sleep mode , just duno why and want it to be on the whole time i use my pc. Can any help ?
Reply to Diabolix
- 0 +
Let me make sure I understand your situation...
Your PC is functioning normally in every way, but it has a diagnostic display on it that you would like to remain visible at all times, but it appears to be set to go off after a while? I.e. it isn't your whole PC which shuts down, it's just this display.
Look for settings in the BIOS. Does the manual offer any useful information on this question?
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
I read it shuts down after 8 minutes to spare the lcd from being damaged. quote : " After eight minutes suspension , the screen will automaticly shut down to protect the PLED display" , but i mean whats thepoint then ?... Does anyone know how to override it ? coz bios has nonthing on it..
Reply to Diabolix
- 0 +
I did not find a link to download a manual at the MSI web site. Sorry, I don't have any other information for you.
Reply to jtt283
- 0 +
Diabolix, I have the same Mobo and personally the only use for that display is to see the CPU and memory voltages and clock speeds, useful for overclocking tests because you see the resultant clock speeds imediately without having to use another program. Once you are stable as your desired clock speed there is really no more use for that display. I have removed it and do not run it at all anynmore.
Reply to Rick_51
How is the MSI X58 Eclipse performance for you ? And what i7 chip are you you using ?
Reply to Diabolix
- 0 +
Rock Solid Brother! I love this mainboard. I have the Intel Core i-7: D-920 proc. on it. At present, I am running the stock clock speed (although this MSI Eclipse board is just slightly over the stock clock of other manufacturers.), due to the fact that when I ordered parts, there were no aftermarket coolers available, therefore, I have been stuck with the stock retail (Coolermaster) cooler provided by Intel. I have completed my research today thanks to the help of a couple of guys on this forum and ordered the: Thermalright Ultra eXtreme 120 socket 1366 version based on comparrison tests conducted by the boys at " Bit-tech.net" Their results show this to be the most efficient performing air CPU cooler for our chips. I expect to over-clock to 3.6 ghz. with that cooler and still run slightly cooler than it does at present at stock clock sped of: 2.66ghz with the retail cooler. Check back in a couple of weeks and I will let you know how it turned out. My rig: Antec 900 mid-twr. case, MSI Eclipse mobo, 12 gig G-skill ddr3 Ram, 2 x MSI over-clocked GTX 280 video cards, ABS Tagen 900 w power supply. OS: Windows Vista Ultimate-64/sp1. This build is absolutely beautiful.
Reply to Rick_51
Okay sounds like an great setup you have there! Ill wait for your reply and will have to see where mine can overclock to.
MSI FTW!
Reply to Diabolix
Hey man , have you overclocked yet ? PLease let me know . Because i would like to overclock aswell , and the temps you got at higher clocks ?
Reply to Diabolix
- 0 +
Hey there Diabolix. Well I am totally game stable 24/7 OC'ed at 3.4 ghz for a week and a half and loving every minute of it. Now I know it is not the 3.6 to 4.0 ghz that some are getting but it is still .2 ghz faster than the mighty 965 Extreme @ $999.00 USD... since my proc was $307.00, that make it all the more satisfying.
I am running 12 gig of ram ( 6 x 2gig ) and I have seen a few coments to the effect that, that ammount of ram can be a speed limitting factor. Temps using "RealTemp" are 41 C at idle and 62 C at 99.6% load with prime95! that is the highest temp that I have seen.
In bios I have "overclock protection off, the EHIST and Turbo off, 20 x multiplier, 170 clock. Ram is manually set to 2T,8,8,8,20 ( this G-Skill Ram calls for 2T 9,9,9,24 but I saw someone else crank theirs up so I tried and the ram seems to like these settings.), core voltage increased by 0.08, pll voltage increased by 0.08, ram is 1.6 volts.
I benchmarked at 175 clock for 3.5ghz, however, 2 hours or so into WOW online, Doom 3, or Left For Dead, I experienced lock-ups. No problems at all at 170 clock. Others are runing faster but I am happy as can be running at 3.4 ghz.
I bought my D-920 1 week after they hit Newegg.com so my chip is one of the first run procs. I have the batch number listed in one of my earlier posts in here: Motherboards/1336 and/or Intel CPU's/1336.
Hope this helps. Good luck with your up-clock. and please let me know how your rig does. Gunny....
Message quoted 1 times
Message edited by Rick_51 on 04-09-2009 at 07:00:11 AM
Reply to Rick_51
- 0 +
Oh yes, I mentioned that I had my processor batch number elsewhere in this forum. I get them mixed up. That info is in the locations mentioned at ocforums.com. That place is all about overclocking and the experienced folks there, will help you every step of the way. That is where I hung out when I began overclocking my rig.... Highly recommended...
Message edited by Rick_51 on 04-09-2009 at 07:01:11 AM
------------------------------ Gorgeous Antec 900 case w/MSI Eclipse x-58,12gig G-Skill RAM,i-7D920,Thermalright120 cooler,2xMSI-GTX280's, ABS Tagen 900w
Reply to Rick_51
- 0 +
yeah id like it to be manually on unless i turn it off.. its kinda cool monitoring my temp.
Reply to jbx907
I agree with that jbx907..
Reply to Diabolix
i think u buy another motherboard cause my msi ecplise ioh north bridge temperature is to hot @ 85c..i7920 at stock speed..*** msi
Reply to Botak136
It's not that hot actually it's a BIOS bug :D Mine also reported that, but after BIOS update it got back to normal...
MSI rocks btw. got my i7 920 to 3.7 Ghz with Noctua SE1336 cooler, no problems in games or rendering - 45 C under full load (it's been almost 3 days since 24/7 render started)
Rig:
MSI Eclipse SLI
Intel i7 920 @ 2.66 (OC 3.7, +0.010 V)
Noctua SE1336
3x2 Gb OCZ Gold 1600
Leadtek GTX 275
Thermaltake Armor+ Big Tower
2 x WD Green 500 Gb (32 Mb Cache) @ Raid0
Corsair 750W TX
PS> I wish the LED could stay on, cause I need to monitor my temps while rendering :(
Reply to ion_tribe
Hey Gunny sorry for taking so long to reply! :(
Anways i got mine overclocked to 3.2Ghz without changing any settings what so all , only the clock speed. And it was stable , well till i played sims 3 then it throwed a blue screen , what can this mean ? I am using Apacer DDR3 1333 (3 X 2GB).
Reply to Diabolix
There are 1322 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
