OCZ PSU making a hissing sound
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - OCZ PSU making a hissing sound
I recently bought a OCZ 600W StealthXStream PSU from newegg. The link to the item is http://www.newegg.com/Product/Prod [...] 6817341010
When ever I am starting a game, it starts to make this certain mild high pitched sound and after sometime it goes away. Note: Only happens wen I am launching a game...but after sometime no audible sound. When desktop its fine too. My concern is, is this an imminent sign of a failure? Why does it make that sound?
Sponsored Links
It's either making that sound because some component is stressed or overheating, or the PSU fan is making that noise because it's crapping out. You could try blowing it out with compressed air, just don't inhale any of the dust that comes out of course. Looking at your configuration it shouldn't be stressed out so it could be dying. If it's just the Fan I wouldn't recommend replacing that if you don't know what you're doing since you can shock yourself pretty bad with those darn capacitors. If you blow it out and it still makes that noise I would turn it off and not use it again until I got a replacement power supply.
Reply to megamanx00
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > OCZ PSU making a hissing sound
There are 680 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
