Hi...I'm new to this forum. I hope you guys can give me a hand here.
I recently built a system based on an Intel DG965WH and a C2Q Q6600. Everything works relatively fine, but I wonder why my outlet fan is running at full speed.
In fact, it looks like this fan is not being speed-controlled (and sounds like being running at full speed). The BIOS "hardware control" utility reports 000 RPM. The fan is a Nidec TA350DC, its connector has a black, a red and a yellow wire (for GND, +12V and Tach I presume).
When I tested another fan on the same header, but this fan having a black, a yellow and a green wire on its connector, the motherboard seemed to control its speed correctly.
Might I be using the wrong kind of fan for my motherboard?
I will appreciate every clue, advise and help.
Thanks in advance.
E.
Thanks in advance.
E.
