Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > gtx 260 cooling solution help!
Forum Graphic & Displays : Graphics Cards - gtx 260 cooling solution help!
hello :)
i have a gtx 260 and im gonna o/c to the ssc setting and i want a good cooler. can anyone give me suggestions?
any help would be great
Sponsored Links
well i dont believe they have a fan for the gtx260 due to the large core, but i would just turn your stock fan speed up.
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
alright. thanks for the advice
Reply to wahjahka
i have a GTX 260 Core 216 oc'ed to the GTX 260 FTW edition speeds with a 50% fan and never go above 65C. the cooling is pretty good on those GTX 260's id say.
Reply to xxcoop42xx
Speaking of upping the fan on the 260, I used rivatuner before but now with 180.XX drivers it seems rivatuner doesn't have the option to up the fan speed, any other program able to do this thats lightweight?
thanks-
Reply to Liderc
thanks-
You can still control fan manually through low-level system settings instead of driver level settings. It's the drop list just above the one for driver level settings.
Reply to dagger
worked perfect dagger, thanks.
Reply to Liderc
dagger is god :)
Reply to wahjahka
Does Rivatuner allow you to monitor the GPU temp?
Reply to Drunder40
There are 1307 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
