Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 9800GTX+ 1920x1200 problem
I recently upgraded my graphics card from ATI Radeon HD2600XT to a XFX 9800GTX+. Everything works fine but I have encounter one problem. Everytime I tried to put it at 1920x1200, which is the native resolution of my monitor (a 24" Acer), it is not working. Everything will be show as "blown up" and about 1/3 of the screen will be off to the right side. When I check my monitor detail it shows that I was using 1600x1200, when I'm clearly running it at 1920x1200. It happen not only on the desktop, but on games also.
So right now I was forced to run it at 1920x1080. Does anyone where know how to fix this problem?
I did tried update/uninstall/reinstall the drivers, but it doesn't help.
Is it the graphic card's problem? If it is I still have time to return it and exchange for another one.
Sponsored Links
I have recently find out that my monitor will shows this problem on any 16:10 resolutions. The whole screen is stretched out and again about 1/3 or 1/4 of the screen are scrolled to the right side.
Anyone have a similar problem and get any solution about it?
Reply to yiiiiiha
Your monitor might not be a 16:10 monitor, set it to 1920x1080. They are starting to make 16:9 24" monitors for some reason.
Reply to The_Blood_Raven
no my monitor has a native resolution of 1920x1200. I have being using that ever since I got the monitor in April. I have no problem using that resolution with my old ATI HD2600XT. Right after I change the video card to the XFX9800GTX+ I can't use that resolution anymore.
Reply to yiiiiiha
nobody knows any solutions =\?
Reply to yiiiiiha
I have same problem. but my native resolution is 1680 x 1050 (22" ) and old VGA(HD2600pro)
nobody knows any solutions ?
Message edited by rizfilho on 04-24-2009 at 05:13:52 AM
Reply to rizfilho
My problem was the HDMI cable. I traded for vga and worked well
Reply to rizfilho
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
