Tom's Hardware > Forum > CPU & Components > Sound Cards > Problem with SB titanium X-FI (NOISE)
Forum CPU & Components : Sound Cards - Problem with SB titanium X-FI (NOISE)
Hi everyone, I've used this Forum to solve so many problems, and now I need help for a problem that i can't solve.
My Specs:
Intel Q9650
Motherboard XFX 790i Ultra Sli
Ram 4gb DDR3
2 x GTX280 XFX 640MHz 1gb (SLI)
PSU 1000W Enermax Galaxy DXX
Windows Vista Ultimate 64-bit
And... a "lovely" Creative Sound Blaster X-Fi Titanium Fatal1ty PCIe
I have the sound card instaled, and with the drivers that came with it.
But I've got a problem. With some games it makes a noise... very disgusting (the sound is similir to the one that makes a radio when it can't get the freqency... interference, it sounds more or less like chakchkachakchakchakchak....).
It happened with Call Of Duty World at War when i throw a gas greanade (but it happens since i upgrade the drivers and the creative console so i downgrade it to the version of the cd and the problem was solved).
With other games like Grand Theft Auto IV it happens more. If you're in a place with Smoke it sounds and at the menu when you select things...
I noticed that if i use a lower audo Quality (the minimum quality that i can use is 16bits 44100MHz), the noise is lower than if I use a better quality (the bigest quality 24 bits and 9600MHz makes a very loud noise). I tried to desactivate the Sound Blaster enhacements and everything but the noise continues.
I think that i have enough PSU, and the Integrated audio card works perfectly (well the quality ofcouse is lower but it never fails, so I'm using it)
Sorry about my english.
I hope you'll find a way to help me
Thanks !
Sponsored Links
Did you disable onboard sound when using the X-Fi?
Reply to Jim_L9
It's possible that you just got a bad card, or one that is incompatible with the most current drivers. Personally I have not trusted creative products for a while. Razer (when you can find em), Diamond, and ASUS have some good sound cards, now anyway. Another thing may be interference with the speakers.
Reply to IH8U
what is onboard sound :S?
Yes, maybe i will change it for an Asus. I Hate creative...
Thanks
Reply to xema25
thats certainly a driver problem. What windows are you using? if the older drivers work perfectly dont upgrade them unless u MUST do it, creative is really bad at Drivers.
Reply to Winly
I'm using Windows Vista x64, i have tried all driver version. D version, Web version and beta version. Now i've got beta, and the noise is very low but it sounds... And i ve disable every cool thing of the card... I think i'm going to throw it to the bin (sell it to a friend) and buy an Asus...
Reply to xema25
I bring bad news. Its most likely your MB. In the past Nvidia chip sets timed out to allow for GPU traffic. It created crashes and loud static on many Nvidia based MBs. Now with PCIE sound cards it makes near exactly the sound you speak of. This is a VERY common problem believe it or not. Other then that you should check to make sure your not putting your spdif output above the default. With vista it often conflicts with SB software and creates a his and or distortion.
Reply to jerseygamer
Same mobo as me, and the same issue with Creative sound cards. Nothing you can do on your end, except switch to either a Razer Barracuda or a ASUS Xonar D2/D2X (both of which work fine, so its not a MB issue, its a Creative one).
I say again:
Do NOT buy a Creative sound card with a NVIDIA based mobo.
Reply to gamerk316
edit: my problem is not sound card related
Message edited by g0dsgreen on 01-09-2009 at 07:44:30 AM
Reply to g0dsgreen
Onboard sound is the sound that comes with the motherboard. If you install a sound card you need to disable it in the BIOS or they will conflict.
Reply to Jim_L9
No they don't; I still have my onboard on with my Barracuda, no isses whatsoever...oh right...Creative...
Reply to gamerk316
I've seen numerous cases where XP will blue screen with the onboard enabled when a sound card is also installed. This might cause his noise problem, but disabling it is an easy test either way.
Reply to Jim_L9
There are 1172 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
