Tom's Hardware > Forum > Graphic & Displays > Nvidia > problems, problems, problems..
Forum Graphic & Displays : Nvidia - problems, problems, problems..
hey, okay i just built my system, updated BIOS, CPU, GRAPHICS CARD, drivers. However, when i run counter strike: source i get high fps for like 5 secs and then drop to 4 fps or less! =/
i've done the 3dmark05 test and i get a score of 2800's! :'( very very BAD.
i basically get 0 fps when running cpu test
something is holding back my system,
here are my system specs:
CPU: amd 3.0ghz athlon 64x2 6000+ temp is @ 40-50 with zalman cooling 92mm and some other 5 fans in the case.
GPU: gtx 260, my card's bus interface is at pci-e x16 @ x16, and the bandwidth is 114.9 gb/s
PSU: 650TX CORSAIR
HDD: 250gb sata/7200 rpm barracuda
MB: http://www.newegg.com/Product/Prod [...] 6813131281
RAM: ddr2 1066 4ghz G.skillz, dram frequency at 375MHz/ 5.5.5.15 timings
MONITOR: 22" HDMI ASUS/1680x1050pixels/59hz
alrite i was wondering if the mobo has something to do with making the system not run like it suppose to, and not get the score im wishing to get, maybe because is a cheap motherboard?? or the ram is affecting the system?? or i should just take it to a shop to take a look around??
any1 could HELP??!!! THX A LOT!! is really frustruating.
Sponsored Links
Ram issue. It shouldnt be running 375.
Reply to roadrunner197069
Check the ram manufactures website and check for the voltage and timing settings recommended and then set it in your BIOS.
Reply to englandr753
There are 1023 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
