Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > Maxtor 3200 personal storage problems
Forum Storage : Hard Drives Maxtor 3200 personal storage problems
hi, i have a maxtor personal storage 3200 500gb, on day i backed all my files onto the hdd to do a reformat of my computer, wheni was done i wanted to put files back but when i powered up the hdd using the proper power cable nothing happened, no little green light and no hdd spin, so i thought it was the usb adapter and opened the casing and put the hdd into a desktop as a slave and nothing happened, it wouldnt even see it in strtup dos, but strangely if i put power to the adapter it works when the hdd isnt present, but plug it in and it wont work again, this is disturbing and i hve not warranty so any help or solutions would be brilliant, thank you
Rockstar skippy
Reply to rockstar skippy
If it isn't recognized in the bios, it is dead.
If it is recognized in the bios, run Seatools and data recovery software.
Reply to evongugg
Thank you, will try and hope it works
There are 1478 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 6 hours ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
