Almost a year ago, i bought a new system with an onboard video card, with the personal understanding that "it's just for a little while until i can afford a video card"
As i said, that was almost a year ago. Money now allows me to do it. Here's what i'm looking at. it's not by any means the best, but it'l work for what i wanna do.
ASUS GeForce 8800GS 550MHZ 384MB 1.6GHZ DDR3 Dual DVI-I HDTV Out DIRECTX10 PCI-E Video Card
Now, although i cannot find the following requirement on THIS card, i do see it on a lot of 8800 series cards, and some even lower.
"Requires 400 Watt Power Supply."
Okay, so i feel dumb for going to for the 350 Watt. But what's it actually going to hurt? I've got almost nothing else in my system. 1 IDE Hard Drive, 1 CD/DVD Combo Drive. That's it. I use onboard sound, onboard networking, and none of my USB Devices are active while i'm going to be using the Video Card. Hell, even the CD/DVD drive should be inactive during gameplay, since i use NO-CD Cracks to keep em that way (I HATE having a game spin up a CD on a level load, when i know damned well it's go the data on the HD)
So i guess my actual question here is, what are the symptoms of not having enough power? Overall "cannot boot", or just slightly lowered performance? With 350 I'm not far off, and 400 sounds like a guess-worked number anyway. Given that i could have a 500 Watt power supply with 3PCI Cards, 4HDs, 5 lights and 6 extra fans, the numbers must have some leeway to them.
Thanks.
Message edited by primalminds on 11-11-2008 at 01:03:35 AM
There are several makers of psu (power supply's) the better ones are rated with wattage at constant load and the worse ones are rated with peak load. If the psu is rated at peak load it cant run at that load constantly wattage does not say it all. The important thing is the amps delivered on the 12 volt line on the psu it is usually on a sticker on the psu it self. Link of a good 350 watt as on example.
http://www.newegg.com/Product/Show [...] r%20Supply
Okay, when i got home last night i took a look at my PSU. Turns out i was wrong, it was a 400W all along. i'm still glad i asked the question though, because now i know about the +12v thing. I still dont really understand it all though, so i'm gonna post this.
Yup, a picture of my very own PSU sticker. Any additional information you could offer now? Think it'l work?
Message edited by primalminds on 11-11-2008 at 05:11:56 PM
