Yes No
Ads
Tom's Hardware > Forum > Networking > General Discussion > Detailed gigabit speed issue
Forum Networking : General Discussion Detailed gigabit speed issue
I have 3 computers networked at my home in which I am trying to improve my network transfer speeds. I have scoured the internet for the last week trying to resolve the issues. I am looking for some help and will try and provide as much background information.
MainPC: EGVA Nvida 680i sli board using onboard Nvidia NIC running Windows XP pro
RAIDserver: Foxconn G31MV-K RTL 8168/8111 pci-e NIC running Windows Server 2008
HTPC: GIGABYTE GA-P35-DS3L RTL 8168/8111 pci-e NIC running Windows XP pro
Swith: D-link gigabit DGS-2205
Using Cat5e cable throughout the network
All NIC drivers have been updated
MainPC: Running 3 Velociraptors in RAID5 with Areca RAID controller - HDtune average speed 220 MB/sec
RAIDserver: Running 8 Samsung drives in RAID6 with Areca RAID controller - HDtune average speed 340 MB/sec
HTPC: 150gb Raptor - HDtune average speed 72 MB/sec
I am most concerned with the speed of file transfers to and from the MainPC and RAIDserver. However, I would like to get the entire network closer to maxing out my gigabit network, which should be close to 120 MB/sec.
Copying files from the RAIDserver to the MainPC, I am averaging about 50MB/sec. Copying files from the MainPC to the RAIDserver, I am averaging about 62MB/sec. Obviously the speed of my harddrives are not the issue. The ethernet cable running from my MainPC to the RAIDserver is only 8 feet. The cable running to my HTPC is probably 75 feet. Speeds to and from the HTPC are about the same.
I have tried enabling jumbo packets on all 3 systems, but have had no luck. It actually slows down the network. The NIC on my MainPC has different MTU settings than the two Realtek NIC's. The options are as follows:
Nvidia NIC: 1500 (standard), 2500, 4500, 9000.
Both Realtek NIC's: disabled (assuming 1500), 2KB, 3KB, 4KB.
All NIC's are set to autonegotiation, though I have tried simply enabling gigabit full duplex. Flow control is on. I have tried enabling and disabling the Qos packet scheduler.
Numerous configurations, cat5e cable swapping, reboots, and other NIC configuration adjustments have not helped. I even used the Nvidia NIC teaming option. Though the speed I am getting is good, I see no reason I should not be able to get closer to 100 or 120MB/sec. This could be an OS, driver, interference or any other issue. I am wondering if I am dropping packets or if the NICs simply won't push higher speeds.
Any help would be appreciated!!!
David
Reply to djdrock
Are you copying one very large file (several GBs in size) or a bunch of small files?
Reply to GhislainG
- 0 +
I have noticed that it does better with a bunch of files, vs one large. The MB/s numbers are for smaller (100mb) chunks of rar files.
Reply to djdrock
Transferring large files often provides better performance. When testing a network, I normally copy files both ways to make sure that there are no issues, particularly with switches and server NICs. As a quick test, I copied a 565 MB file on my home network and it takes 10 seconds from and to the server, therefore I know that my LAN works fine. My transfer speeds are somewhat limited by the SATA hard disks.
Reply to GhislainG
There are 1488 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
