New System Build
I'm going to build a new System.For Gaming.
The First Spec :
Processor:Intel Core 2 Duo E8500 3.16Ghz
P45 Platinum
Kingston HyperX Memory 2GB X 1GB 800
Seagate 500 SATA Hard Disk 7200rpm
ASUS EAH4670
And the Second Spec:
Processor:Intel Core 2 Quad Q9400 2.66ghz (I going to overclock it to 3ghz)
MOBO : P45 Platinum
RAM:Corsair Dominator 2Gb X 1GB 800
Hard Disk :Seagate 500 SATA Hard Disk 7200rpm
GPU:ASUS EAH4670
Can you tell me how it is ? :bounce:  :bounce:
More about : system build
amd_overclocker said:
well performance wise, your second choice is better, what cooler are you going to use for the cpu? also i would suggest for your ram a 2x2 kit. newegg has corsair for about $40.
I am going to use CoolerMaster V8
Ask the community
