I just bought an Antec Case from NewEgg (http://www.newegg.com/Product/Product.aspx?Item=N82E16811129033)
It came with a 430w power supply.
I am buying a motherboard, cpu and vid card next and want to know if the following will work on the PS in the case:
Biostar GF7050V-M7
Core 2 Duo E8400
EVGA 01G-P2-N793-LR GeForce 8500 GT 1GB 128-bit GDDR2 PCI Express x16
I wont be adding anyhting else.
So, will the power supply hold up or do I upgrade to something larger?
Also, I am open to comments on these three components as well!
Thanks
Biostar GF7050V-M7
Core 2 Duo E8400
Thanks
