Hi,
I've just installed my EVGA 9800gx2 and I love it!
One thing that's puzzling me (go easy on me technically)....
There is a little audio cable supplied. You stick one end in the card, and the other end in the mobo. It's a 2 pin cable.
Apparently, it supplies 5.1 sound to the card, which can then travel through the hdmi cable to my telly.
The problem is, I can't find where the little 2 pin cable connects on to the mobo!
I have an ASUS M2N4-SLI mobo, which I am told has the correct connection available.
Does anyone know where it is, and more challengingly, does anyone know how to explain to me how to find it?
It's for sound in hdmi output. You're supposed to plug the other end into your sound card or onboard sound. Every card/board is different, but it should be on there somewhere. If you don't use hdmi, it's fine to leave it out.
This is specially for HDMI sound, just connect the supplied spdif cable to the card and the other end to the mobo, in my ASUS is a 4 slot with 3 pins.
This allows to get sound through the HDMI cable, don't need a sound card.
this might work. right click the speaker by the clock on the taskbar and then click playback devices. right click any white part on the window and click disabled devices... now the hdmi sound output should appear.. just right click it and select enable or set to default
Hi, thanks for your reply. Someone else told me to try this also. Unfotunately there are no other playback devices shown, even when ticking the 2 boxes.
Very wierd. I have searched just about every sound related window I can find and loads of different forums and still not solved the problem
in windows vista, select start, control panel, sound.on the playback tab, select the spdif output device and select Set Default. I do not have vista but an the cd that came with the card I put it in and found a view manual as one of the choices and and scrolled thru it. Doug
