Tom's Hardware > Forum > Motherboards & Memory > MSI-Microstar > Problem with 865PE Neo2-FIS2R and 8x AGP
Forum Motherboards & Memory : MSI-Microstar - Problem with 865PE Neo2-FIS2R and 8x AGP
Hi all,
I recently acquired an MSI motherboard - the 865PE Neo2-FIS2R (info)
That's been working fine for some time, but I came to replace the old 4x AGP Siluro GeForce 4 Ti4200 (info) with a Gainward PowerPack! Ultra/2100LE GeForceĀ® 6800LE (8x AGP) (info) from a reputable seller on eBay. This, I am assured, was working fine when it was dispatched!
Obviously I observed proper precautions regarding static, and fitted the card.
On starting up, the POST screen is visible, but lots of small green horizontal lines (appearing in 10-12 columns) flicker and distort the screen. Past this, i.e. changing video mode to boot Windows or Ubuntu, anything on the screen is not recognisable at all.
Theoretically, the motherboard supports 8x AGP at 0.8V, and the video card is 8x AGP and requires 0.8V. So this should be compatible. But there's a problem somewhere.
What I know: the motherboard is working fine with the 4x GeForce 4. The motherboard was using a 4x Radeon 9800 Pro with its previous owner. It hasn't been used with 8x AGP before.
The BIOS wasn't upgraded until recently (was v1.2 I think) but while trying to sort out a boot problem I flashed it to the "current" (i.e. 2004) BIOS. Hopefully that's not the reason that this problem has been introduced...
So, the questions - has anyone found similar problems with 8x AGP on this mainboard? Does anyone have 8x AGP working fine - and, if so, what BIOS version are you using? How can I be sure that the motherboard is operating in 8x mode and supplying 0.8V instead of 1.5V?
Thanks in advance for your help,
Paul
Sponsored Links
The 6800 was notorious for overheating and self destructing itself into a technical marvel paperweight. Return it.
Reply to badge
^ +1. IMHO, buying a used GPU off eBay is asking for problems, especially an old AGP card. Just asking for trouble, I don't care what the seller says. The display patterns you describe are the signs of a failing or trashed GPU.
Reply to jitpublisher
Yeah, I know what you're saying - I used to have an ASUS 6800 but that died an unexpected and unknown death. This 6800 has an Artic Cooler NV5 fitted so heating shouldn't be much of a problem. It's unfortunate that I can't get it tested so easily - I could take it to a local independent shop, but they're doubtless going to charge for the privilege.
I asked him this morning about returning it and am awaiting a reply...
Reply to Anonymous
There are 887 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
