I7-920 overclocking help
Rockmar
14
I've been trying to overclock my i7-920, and I've run into a blockade. I simply can not figure out a way to get it to run at over 3.2 Ghz. I've tried jumping the voltage up to 1.35 and I've tried dropping my memory frequency down to make sure that it isn't the problem, but it still always bluescreens as I'm trying to boot windows. Do you think that I just got a CPU that's really bad at overclocking, or is there something that I'm forgetting to do? Thanks in advance
bigstott
69
No you are just missing a step somewere. Have you read the i7 overclocking guides??? To be honest you can get away with setting everything on auto taking your base clock to 175 restarting and it should be fine. What mobo do you have???
Rockmar
14
I've got the EVGA SLI LE motherboard with the phoenix award BIOS. I've read several guides, and followed them as best as I could (sometimes they talked about changing settings that I couldn't find) but nothing has worked.
bigstott
69
did you enable the dummy oc??
Vdroop?
Try This:
Mother Board ( EVGA X58 LE )
Frequency Control
CPU Clock Ratio ( 20x )
CPU Host Frequency (Mhz) ( 186 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 16x )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 101 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 2:8 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( 1.3 )
CPU VTT Voltage ( +125 )
CPU PLL VCore ( Auto )
DIMM Voltage ( 1.65 )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( Auto)
IOH VCore ( Auto)
IOH/ICH I/O Voltage ( Auto )
ICH VCore (Auto )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s )
OC Recorvery ( Enabled )
