Hi ,
My brother got a E8400 CPU and foxconn P45A-S mobo about a week ago. it was working just fine.. now the problem it has the pc shuts down automatically after couple minutes when turned on. I've checked all the components except the CPU and motherboard.
the e8400 CPU hits the temp 58 ( some times 60) once powered up the machine . it's with stock cooling fan. is this normal ? I have attached the heat sink with enough pressure. but I noticed if I remove the heatsink and put it back again sometimes it starts with temp 72 .
the pc shuts down automatically so now I'm confused.. is it an issue due to overheating the cpu or some problem with the mobo. also I noticed now I'm unable to install windows xp to this pc. each time at the screen where xp setup installs devices before installing networks, the pc turned off automatically and after 2, 3 seconds it boots up again automatically. also ubuntu live cd doesn't run on this too. once the loading starts...it shuts down..
I'm not sure to do a bios update on this board cause I don't know when the PC will shut down. Also I've flashed the bios once before this issue happen and now I have the feeling that I made this system faulty by updating bios.
please let me know your ideas about this one...all the parts are new and not older than a 2 weeks .
thanks for your time...
