Just got it in the mail, brand-new from Newegg.com
So here's the issue...
Hooked it up the first time and it took me all the way into windows, then just crashed. I figured I had a loose cable or something, so i unhooked and hooked everything back in...
Then it wouldn't power up. Motherboard LEDs were all on, but when I hit start it start spinning for a moment then kill...
This power supply is VERY sufficient to do the job. (considering I'm currently on my crap 550W Rosewill)
It happens, but i'd be surprised if it did. Double check to make sure you have all your connections right and haven't used a cable in the wrong place, double check the manual reading it carefully. If it doesn't work after that then either RMA it or contact customer support at Corsair (they have a great rep, but i've never needed them)
I had the same issue today. I also received a Corsair HX1000W power supply from Newegg about 4 days ago. Everything worked fine for a few days, but when I tried to power on the computer this morning, there was only a very brief spin of the fans and lights and then nothing after, just like you experienced.
I attempted a PSU test that was supplied by the Corsair support forums, maybe it will help you determine whether or not you got a spoiled egg:http://www.asktheramguy.com/v3/showthread.php?t=63991. When I performed this test, my PSU was unable to power the fan, so I'm thinking the PSU is faulty.
I've RMA'd the psu, and will be receiving a new power supply tomorrow (same model). I'll test it out and see if anything improves. I'm hoping I was just unlucky with the first one.
Message edited by Jayfar on 01-14-2009 at 05:21:49 AM
