I'm putting together a list of components for a new high end gaming system. I've built one computer in the past, so would call my skills pretty limited. I don't know much more than how to follow an online guide, so there will be no special tricks (i.e. overclocking).
I'm wondering if these components are all compatible and if you recommend any other items than what's listed. I'd like this to be pretty high end, expandable in the future, and run very quietly. Thanks in advance.
CPU - Intel Core 2 Quad Q9550 2.83Ghz http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
Motherboard - Foxconn Destroyer AM2+/AM2 NVIDIA nForce 780a SLI ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186152.
Heatsink - ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra Quiet CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118020
Ram - CORSAIR XMS2 DHX 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145217
Case - Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Power Supply - COOLMAX CUQ-1200B 1200W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159067
Fan - Scythe S-FLEX SFF21D 120mm Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185004
Hard Drive - Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136260
DVD-RW - LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Video Card (do I need two of these?) - XFX PVT98UZHDU GeForce 9800 GX2 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150301
Sound Card - Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Series 70SB088600007 7.1 Channels 24-bit 192KHz PCI Express Interface Sound Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102021
Network Card - Do I need to buy one of these separate? I haven't found one yet.
I already have a gaming mouse, keyboard, and OS.
