Hi
I want to change my air cooling system for a water cooling system because my heatskin is a CM V8 and it´s very big.
But I have a couple of questions
1.-It´s more effective than the air cooling?
2.-I need to upgrade my PSU? (I have a MoBo ECS A780GM-A, CPU Phenom X4 9750 2.4Ghz, RAM 4Gb DDR2 800Mhz, Sapphire ATI HD4890 1Gb, HDD Seagate 500Gb Sata II, Lite on DVD-/+RW, Heatskin CM V8) all this with a CM realpower 750W, if I change the V8 for a water cooling system it will fine with this PSU?
3.-Can I use only one water system for the CPU, GPU and Chipset cooling?
4.-Which is the better water cooling system?
Thanks for your help
