Tom's Hardware > Forum > Homebuilt Systems > New System Build > First build, can I use recycled parts
Forum Homebuilt Systems : New System Build - First build, can I use recycled parts
MoBo: Asus P5B-VM SE - $74.99
http://www.newegg.com/Product/Prod [...] 6813131178
CPU: Intel Core 2 Duo E7200 2.53GHz 1066MHz FSB - $114.99
http://www.tigerdirect.com/applica [...] CatId=2396
Hard Drive: Seagate 250GB 7200RPM - $43.50
http://www.ewiz.com/detail.php?name=HD-ST250S3
OS: not sure (XP or Vista) - free student download
RAM: not sure yet
Total = $233.48...give or take.
I'm planning on building a pretty simple system; nothing too big. Right now I have an HP Pavillion a1010n; pretty old system. This system has a P4GV-LA mobo.
I was wondering if I could use the same CD and DVD drives that I currently have on my computer. Also is there a way to use my current h. drive as well, without having to reinstall the OS and stuff. I will be using my current case as well.
Any tips on starting a new build appreciated.
Sponsored Links
Most likely, you can use the case.
You will have to reinstall the OS, unfortunately.
The DVD/CD drives should still work.
Reply to SanjiWatsuki
You can probably use the case as long as HP aren't using non-standard mountings.
The motherboard will have an IDE socket on it so you should be able to reuse your HDD and either a DVD or CD. Max support for 2 IDE devices.
I'm assuming that they run on the old tech, if they use SATA then you are laughing!
Using the old HDD shouldn't be a problem and you shouldn't need to reinstall the OS. Windows might get upset because you have put it into the new machine and you may need to ring up to get a new validation code.
Just another note, the board you have picked uses intergrated graphics, is this what you want? You could expand with an dedicated graphics card later.
Jeremy
Reply to jpdykes
Jeremy
Yup, my CD and DVD drives connect via IDE. My old h.drive connects via IDE as well, but the new mobo only has one IDE connector, that's why I'm getting a SATA h. drive: also because I want more h. drive space.
And yes, I wanted integrated graphics. Like I said, I don't really plan on getting a powerful system, so built in video is fine with me.
So I can use my current CD and DVD drive with the new mobo? Will I need to download/update any drivers and stuff?
Also, I heard with a new mobo, you need a new OS install. But anyways, thanks for the info.
Reply to sdcman1
i think i would get these instead for a build like this
Motherboard: GIGABYTE 780g microatx $80
http://www.newegg.com/Product/Prod [...] 6813128090
CPU: AMD Athlon 64 X2 6000+ 3.1GHz $92
http://www.newegg.com/Product/Prod [...] 6819103272
Ram: pqi TURBO 2GB ddr2 800 $29
http://www.newegg.com/Product/Prod [...] 6820141064
Message edited by gators1223 on 10-19-2008 at 09:59:16 PM
Reply to gators1223
You CAN reuse your current Windows installation without reinstalling.
I have done it several times. You have to do a repair install though.
However, I can say it is much better to do a clean new install.
You will never ever be able to get all the bugs completely out when you transfer a previously installed OS to a new system. It may work well enough for most, but it will be flaky somewhere.
Reply to jitpublisher
+1 for jitpublisher. Using an SATA to boot from will be better anyway, faster transfer than IDE.
You could only attach one optical drive and transfer stuff from the old drive. Then reattach the second one.
Jeremy
Reply to jpdykes
In my experience, if you want to use that HP case then you're gonna need to jerry-rig up some sort of adaptor, as the front-panel headers on their boards are not of a standard layout.
HP tend to use a single block layout which means that trying to use their cases with any generic hardware is a nightmare. I've got around this issue in the past by creating an adaptor board, that hooks up to the block connector on the case using a small piece of prototyping board and a set of header pins, but it's not for the feint-hearted.
You can usually use their main-boards in a generic case, but that's not the issue here.
To do the mod, you need...
Prototyping board (Veroboard)
Soldering equipment
Multimeter
A scrap case
Header pins
Hot glue gun & glue
Exacto-Knife
You can get the Veroboard & Header pins from any electronics shop e.g Radio Shack or Maplin Electronics. Any scrap PC case will do, all you need from that is the front panel header connectors that you will solder to the Veroboard so that you can hook them up to your new board.
Cut off a section of Veroboard with the exacto-knife roughly the size of the block connector on the HP case. Make sure you do this so the tracks on the underside go from top to bottom when orientated horizontally...
You will need at least 6 rows by however many columns there are on the block connector. Next thing to do is to solder the header pins to the veroboard. Once you've done this, cut the tracks on the board between the two rows of pins with the exacto knife so that the meter shows "open" between the pair of pins in each row. THIS IS IMPORTANT, AS DAMAGE WILL RESULT IF THESE TRACKS ARE NOT CUT PROPERLY.
Next, Lop the front panel headers off the scrap case giving you as much of the cable as you need and bare off the ends. You will be soldering these cables to the outside edges of the veroboard header you've just made. Again, it's important to take your time with this bit as you'll need to read the pinouts on your original HP board to try and figure out what pin does what. The other option is to carefully remove the front of the HP case and follow the wires up from the block connector. Do whichever is easiest. Sometimes the original mobo isn't marked, in which case, the only option is to trace the cables up the front of the case. The exact pinout varies from board to board, but the theory stays true.
What you should have at the end of all this is a piece of PCB that has a load of pins in the centre two rows. Your HP's block connector connects to these, and wires coming out top and bottom, terminating in the header hookups from the scrap case. These will hook up to your new board.
Check everything over with the meter and make sure that all the connections are good and nothing is shorting out where it shouldn't be. Once you've done this and are satisfied that nothing is shorting out and everything is isolated, use the glue gun to encase the PCB part in hot glue. Make sure you leave the pins clear. This will provide insulation and prevent shorts when you place it inside the PC chassis. Once you've done this, plug your block connector on the pins in the veroboard and the corresponding free headers on the other end into your new board.
Good to go!!
I volunteer at a local PC re-use & recycling project and have jerry-rigged a number of PC mobos with custom FP headers in this way. Likely candidates for jerry-rigging are all HP, most Packard Bells and quite a few, if not all Dells too.
Reply to Gareth Lock
There are 1294 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
