OCZ ProXStream 1000 Watt Power Supply
kayawish24
47
hello people..........!
i want to ask that OCZ ProXStream 1000 Watt Power Supply will run my 3 x 8800 gtx Tri SLI safly or not??? specs for this PSU are:-
- 115Vac 60Hz / 230Vac 50Hz
- +3.3V(28A), +5V(30A), +12V1(20A), +12V2(20A), +12V3(20A), +12V4(20A) and the combined +12V(1-4) is 70A????
what do you think now will it run my system??
q6600@ 2.4 Ghz
Asus P5n-t Deluxe
3 x 8800 gtx (stock)
320 HDD S-ATA
1 x DVD RW
5 x 120mm case fans
MTIH1992
19
Easily.
I checked your spec using Antec's Power Supply Calculator, and although it doesnt have the option for tri-SLI, with Dual SLI at 90% system load it would only be using 475W, so even if you add another card to that, (proberbly about ~130W) 1000W would still give you plenty of room.
http://www.antec.outervision.com/
