I've gotten a lot of great info from reading the forums, but I've never built a system from ground up, so if I could get feedback on a potential build, I'd appreciate it.
My husband thinks it would be less trouble to just get a $800 Dell, but I'm not thrilled with the components at that price point, and I've done a lot of interim upgrades on our old system so don't mind doing the assembly myself. We won't be overclocking or running more than one video card, but I also don't want to be immediately obsolete. For gaming, we play Atlantica and Guild Wars right now, and our current system can't even always handle real-time rendering of the other players.
Other uses are Office Suite and some graphics editing -- Adobe Macromedia suite and basic photo/video editing) I'm looking at the following components:
Not sure if the video card is overkill for our needs, but I appreciate all advice. I tried to share a wish list for this build at NewEgg but am not finding it on the public list. Does this work?
Seems like that system would be perfectly ample for your needs, and would be pretty futureproof too. For games such as those mentioned that card is fine.
However, to be completely honest unless you're a DJ or something to do with heavy audio editing etc, the onboard 7.1 Surround on the motherboard would easily cope. I run a high spec gaming machine, but use onboard audio as - well tbh I can't tell any difference between my humble onboard sound and Mr Fancy's $300 Soundblaster.
Thanks -- I wasn't sure if the onboard audio would handle the video rendering, so was tossing in the card just in case. Glad to shave off a few extra dollars!
We're running XP, so I know it won't see all 4GB of RAM -- does it cause any problems to put them in anyway?
No problems will come from having 4GB of ram. As you already stated you just won't see all 4GB in windows, it'll be 3. something.
Reading the various builds on the forums, I notice a trend towards the P5Q Pro as a standard mobo -- is there a particular reason to select that one over the standard version I listed? There is only a $5.00 difference in the list price on NewEgg.
