All right. I think I have found some pretty good parts as far as everything else goes, but i am having touble finding a motherboard that is right for me.
As for things that I want on my motherboard I need it to have at least 1 PCI express 2.0 x16 slot for my gpu. Also, it should have 4 slots for my ram. (open for new ram suggestions 4gb please). I am new to building computers so please help me choose one that is stable and will last. I do not play to over clock. I am going AMD if you didn't see. I would prefer something around 80-90 dollars.
The Athlon is a slow CPU. I can really only recommend the Phenom 9950 right now, and even that is problematic as the current motherboards will probably not be compatible with the new CPUs coming from AMD in Dec.
For about 50$ more you could build a faster Intel rig.
I am on a night budget as it is, I cannot spare $50. Its 3.2Ghz dual core. Why isn't that fast. It must be better than my 2.0ghz core 2 dou that I'm on now.
I see that tomorrow the E7300 should be the same price as the Athlon. Roughly the same performance or slightly better, but with a far better upgrade path and excellent overclocking.
Pair that with a P43 board and you could do both for under $200.00.
You would also not need the Reapers. get some Mushkin DDR2 800Mhz for around 50 bucks after rebate. See my link above for parts.
A good motherboard choice would be the Biostar TA 790GX with the 750SB at $100. It has PCIeX16 2.0 socket and can crossfire 8x/8x if you want to go that way in the future. Check out it's combo deals also -$15 off on your choice of RAM. You can save an additional $12 and not have to screw with a rebate by getting this Antec Earthwatts 650w power supply for $65, free shipping
http://www.newegg.com/Product/Prod [...] 6817371015 review of that power supply
