I'm a 1st time poster but i've been reading around for a while now. I want to build my first computer ever and need some advice from the pros. I am going to use it mainly for gaming and i do want to play games at max or near max settings.
OK, this is the list of components I'm planning on buying so far. But have not made up my mind on alot of them. That's whre you guys come in.
11] OS - I don't know if i should get XP Pro (since I'm familiar with it) or make the jump and get Vista 64bit.
12]As for all the other extra stuff, i'll probably get a 22" later, got the keyboard and mouse, and i do want a wireless connection so I was thinking of getting THIS.
Please give me your thoughts on my build and feel free to make any recomendations. Thanks.
- PSU: Corsair, enermax, pc power and cooling - any will be good reliable supplies.
- Graphics: ATi 4000 series are the way to go at the moment. 9800 is older technology. If the budget fits 4870 go with that, especcially if you are after max graphics quality.
- RAM: Unless you want large overclocks go DDR2-800, will work fine and you'll only notice the money saved!
- CPU: Probably E8500 or Q9550 is the choice. For ultimate gaming at a given price point dual still seems to be the best, but if you can afford the Q9550 that will beat the E8500.
- Clarification: E8500 vs Q6600, same price, dual usually performs better in games. E8500 vs Q9500 - Q9550 should win easily.
- Seagate is fine for HDD and 500Gb should last ok as long as you aren't planning on ripping HD movies.
- Heatsink - only required if overclock. If so Xigmatek.
- Go to a 64bit OS for best use of RAM and DX10 in games.
Jeremy
Thanks Jeremy for the quick responce.
- PSU, i'll probably get a Corsair or enermax brand like you sugested.
- GPU, i really wanted to stick to nVidia and 4870 would be nice but it's kinda pricy.
- RAM, I'll probably go with the DDR2-800 and save some $$$
- CPU, i'm going to go with the E8500 and put all the savings onto a 22" monitor.
- Heatsink, i won't need any cause i'm not overclocking, right?
- and for OS, i dont know if to get Home Premium or Ultimate
Jeremy
I agree with the above except for the HD. I would highly recommend the WD6400AAKS drive since it's considerably faster, has 140GB more storage, and is only $5 more.
I suggest heeding the advice about the ATI 48x0 series cards. I would take a close look at the 4870 1Gb GPU. Read through this article and look at the games and resolution you will be gaming at.
If you decide to go that route you should also get a nice X48 chipset board from ASUS or Gigabyte to allow full speed crossfire in the future. The GA-X48-DS5 is a very nice board.
Any other sugestions guys?
I would just stick with 64-bit Vista Home Premium. Here's a link to the comparison between Ultimate and Home Premium:
I'm going to back short_stuff on some of his post.
- Go WD, sounds good to me.
- If the 4870 is too pricy, maybe look at the 4850. Should still lay waste to 9800 offerings.
- I don't support the case for X48 motherboard especcially not at 22" res and on a medium budget. If you were to add a second graphics card later you might expect to loose 5% at a high resolution when compared to the P45 chipset. 22" you would hardly notice the difference.
That's true. If X48 is out of the budget just stick with a nice P45 chipset board. It sounds like the OP has his mind set on Nvidia for some reason though.
To the OP - I hope you read through that GPU comparison linked above and don't let a bias toward Nvidia make your decision for you. The numbers speak for themselves. The Intel chipsets are also superior to the Nvidia ones.
I would just stick with 64-bit Vista Home Premium. Newegg carries Vista Home Premium for $100:
I will get this OS. Thanks.
Can you guys post some links to Mobos and Video cards comparable in price to the ones i had intended to purchase. You are so close to changing my mind right now.
Here's what I got so far. Newegg cart Can you guys see it?
Message edited by d_mon1 on 10-22-2008 at 12:33:56 AM
Get this power supply in combo with your case choice. At $50 after the combo deal, you can't beat the Antec Earthwatts 650w.
http://www.newegg.com/Product/Prod [...] 6817371015 Get a P45 motherboard that supports 8x/8x crossfire. At about $115 it's a great deal, stable, works better then a Nvidia chip motherboard, offers better performance at a better price.
http://www.newegg.com/Product/Prod [...] 6813128358 Xigmatek cooler with bracket
Western Digital 640GB HD
2x2 GB DDR2 800 RAM
Vista Home Premium 64 bit
any HD4850
Message edited by dirtmountain on 10-22-2008 at 12:34:43 AM
Some quick thoughts having only read the OP's post:
Get the dual-core.
If you are set on one of those mobos, get the 750. You have no need for the 780. Or you can get a X48 or P45.
Definitely get a Corsair PSU, none better.
Since you saved some money with these choices, you can definitely get a better GPU, either the 4870 or the GTX 260. Either of these should last you a couple of years. You won't be able to play everything maxed maybe, but it'll get the job done.
Read the article in the above quote. You will see that the 1GB model helps in some games at high resolutions with AA enabled. If you play GRID the difference is huge! It's only $30 more than the 512MB version.
Which PSU you choose depends on if you think you'll ever add another GPU in a crossfire setup. If you will, I would recommend the 750TX. The 650TX would work great with one 4870.
Edit: I just noticed you have a quantity of 2 for the motherboard and CPU. You might want to change that before pulling the trigger!
Thanks for the heads up on the double components. And thanks for the dvd with lightscribe deal.
My friend was telling me if i'm going with AMD, i should get an Asus mobo. But wich one? I'm willing to pay $200 for a decent mobo. Any ideas wich one?
I would have to question your friends reason for suggesting an Asus board with an AMD GPU. I have had very good luck with Gigabyte boards and AMD GPU's. The one in your wish list is a very nice board. I don't see any reason to change it unless you want to step up to a X48 chipset board. The X48 boards run about $220+ though.
Guess I'll keep the one i've got there then. Thanks A LOT to everybody that helped me out on this! Now I've got to finish saving up so I can order all the parts at once. Thanks again!
